Trying to parse JSON and match specific values out
Gilad Waldman
Hello, I have a field that is populated with multiple platform versions :
{ "Browser": ["1.2.3", "1.23.0"], "Extension": ["1.8.6p"], "Protect": ["1.98.4p", "1.98.4p", "1.98.4p"], "SSH": ["1.87.0"] }
Am trying to build an automation rule that parse the text and brake it into different fields like this:
Browser ->  ["1.2.3", "1.23.0"]
Extension -> ["1.8.6p"]
I first tried to use this smart value : {{ issue.customfield_10582.asJson."Browser"}}
but i get nothing, so was trying to use asJsonObject but still can match.
any ideas?
September 4, 2025
Hi @Gilad Waldman
Please try using the function jsonStringToObject() to convert the plain text to JSON which can access the elements with dot-notation:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#jsonStringToObject--
Marc - Devoteam
September 4, 2025
Hi @Gilad Waldman
You will have to use smart values, based on text options.
Then create a variable and use the smart value: {{issue.customfield_10582.substringBetween("[","]")}}
Then log this as well and see what you get as result.
With an edit action set the field based on the variable.
Gilad Waldman
Wondering why... this should JSON should be easier to extract data from.
Marc - Devoteam
September 4, 2025
Hi @Gilad Waldman
Then you need to set the options as an array.
{{issue.customfield_10582.asJsonStringArray}}
See https://support.atlassian.com/cloud-automation/docs/jira-smart-values-json-functions/
Gilad Waldman
familiar with the documentation, thanks. its just keeps returning empty value
Gilad Waldman
for example, if i use
asJsonObject: {{issue.customfield_10582.asJsonObject("Browser")}}
I'm expecting to get the values ["1.2.3", "1.23.0"] but instead im getting:
{ "Browser": "{\"Browser\": [\"1.2.3\", \"1.23.0\"],\"Extension\": [\"1.8.6p\"],\"Protect\": [\"1.98.4p\", \"1.98.4p\", \"1.98.4p\",\"1.1.1\"],\"SSH\": [\"1.87.0\"]} " }
Marc - Devoteam
September 4, 2025
Hi @Gilad Waldman
What do you get on using {{issue.customfield_10582.asJsonStringArray}}
What you expect is not right, as the values you are trying to fetch in a single field, so you get everything.
You will 1st need to get the values in an array and from the array use the values you want to place in the respective fields.
Gilad Waldman
Ok that helps, im just not sure why it doesnt allow me to break it into an array
When I'm using asJsonStringArray Im not getting back any value
Only if I'm trying to use asJsonObject as seen above
Marc - Devoteam
September 4, 2025
Hi @Gilad Waldman
As mentioned before the information you have is text, so you need to split this content, you can use the text smart value options for this.
See this form post on why setting text as as json object is hard and iratic.
https://community.atlassian.com/forums/Jira-questions/Parsing-a-text-field-with-a-JSON-object/qaq-p/2260884
Yash Smith September 4, 2025
Can you please explain in detail?
Gilad Waldman
explain what exactly?
