×Dears,
I'm facing an issue with my jira.
I have followed below link without missing a single point.
I don't have an issue when running using http, but I have tried to setup the Jira configuration tool with no go.
Please help.
So what are you doing differently to what the doc says and what are the symptoms?
Not that I know of.
I got this result when I run it through https. I did roll back to http on order for it to work.
I'm not sure if my issue is with the certificate or something else.
The error message here is clear - you have not made the changes required in server.xml. Take another look at that file.
For what it's worth, most people who ignore that part of the doc either don't read the bit about commenting and un-commenting the right section, or they don't read the bit about the port number and pick a random one mentioned elsewhere in the file because it's a number.
Thank for your reply.
I haven't ignored anything.
My jira version is 8.11.0 and it says I don't need to edit server.xml file. !!
Please advice.
Where does it say you do not need to edit the server.xml?
Could you please follow the documentation and not diverge from it. Then retest? If you do what the doc says, it will work.
Thank for your support.
Please advice as all what I need to edit was already edited by the tool.
<?xml version="1.0" encoding="UTF-8"?><!--
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
--><Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener"/>
<Listener SSLEngine="on" className="org.apache.catalina.core.AprLifecycleListener"/>
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/>
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/>
<Service name="Catalina">
DEFAULT - Direct connector with no proxy for unproxied access to Jira.
If using a http/https proxy, comment out this connector.
<!-- Relaxing chars because of JRASERVER-67974 -->
<Connector acceptCount="100" bindOnInit="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="8443" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>" useBodyEncodingForURI="true"/>
HTTP - Proxying Jira via Apache or Nginx over HTTP
If you're proxying traffic to Jira over HTTP, uncomment the below connector and comment out the others.
Ensure the proxyName and proxyPort are updated with the appropriate information if necessary as per the docs.
See the following for more information:
Apache - https://confluence.atlassian.com/x/4xQLM
nginx - https://confluence.atlassian.com/x/DAFmGQ
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" scheme="http"
proxyName="<subdomain>.<domain>.com" proxyPort="80"/>
HTTPS - Proxying Jira via Apache or Nginx over HTTPS
If you're proxying traffic to Jira over HTTPS, uncomment the below connector and comment out the others.
Apache - https://confluence.atlassian.com/x/PTT3MQ
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="<subdomain>.<domain>.com" proxyPort="443"/>
AJP - Proxying Jira via Apache over HTTP or HTTPS
If you're proxying traffic to Jira using the AJP protocol, uncomment the following connector line
Apache - https://confluence.atlassian.com/x/QiJ9MQ
<Connector port="8009" URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3"/>
<Engine defaultHost="localhost" name="Catalina">
<Host appBase="webapps" autoDeploy="true" name="localhost" unpackWARs="true">
<Context docBase="${catalina.home}/atlassian-jira" path="" reloadable="false" useHttpOnly="true">
<Resource auth="Container" factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60" name="UserTransaction" type="javax.transaction.UserTransaction"/>
<Manager pathname=""/>
<JarScanner scanManifest="false"/>
<Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="120"/>
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve" pattern="%a %{jira.request.id}r %{jira.request.username}r %t "%m %U%q %H" %s %b %D "%{Referer}i" "%{User-Agent}i" "%{jira.request.assession.id}r""/>
</Engine>
<Connector SSLEnabled="true" acceptCount="100" clientAuth="false" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" keyAlias="jira" keystoreFile="C:\Program Files\Atlassian\Application Data\Jira\jira.jks" keystorePass="Imnotsharingthis" keystoreType="JKS" maxHttpHeaderSize="8192" maxSpareThreads="75" maxThreads="150" minSpareThreads="25" port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol" scheme="https" secure="true" sslProtocol="TLS" useBodyEncodingForURI="true"/></Service>
</Server>
Sorry for the duplicates.
It wan't posting my answer and now I have 3 answers :)
There's a bit of a bug in Community that does this intermittently, it's not your fault, no need to apologise.
And thank you for cleaning out the duplicates, making everything easier to read!
If I am reading it correctly, your server.xml has a commented-out connector for plain http, and an enabled one for https. The http connector includes two directives that start with "relaxed", but the https one does not.
I think you want to add those two directives to the https connector
Thank you for your support.
It work now after adding missing lines in the HTTPS.
