We are trying to prototype using a script to account for the following scenario:
If a story in the demo status is transitioned to the next status of 'Accepted', a transition screen is popped up which contains a field called 'Bug Management' which is a checkbox. We want to set this field to read only IF the story has a linked bug to it which is in the open status. Also need to show an error message on the screen, or under the screen when the field is set to read only due to matching the conditions
How can this be accomplished? Using behaviors or script listeners?
Started off with the following code which is not working:
import com.atlassian.jira.issue.IssueFieldConstants
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.issue.status.Status
import com.atlassian.jira.issue.issuetype.IssueType
import com.atlassian.jira.config.ConstantsManager
import com.atlassian.jira.config.StatusManager
def Field = getFieldByName("Bug Management")
def StoryStatus = StatusManager.name == "Accepted"
//def LinkType = IssueLinkManager.any()
if (StoryStatus && LinkType == (true))
{Field.setReadOnly(true)}
Thanks & Regards!
