Hi Team,
I need to configure two-level cascade select list using JMWE groovy.
We have JMWE plugin only.
let I have two custom field called select1 with value 'Big' and 'Small'
and select2 with values 'A' 'B' 'C' 'D' 'a' 'b' 'c' 'd'
If I select Big from field select1, field sselect2 should populate 'A' 'B' 'C' 'D'
If I select Small from field select1, field sselect2 should populate 'a' 'b' 'c' 'd'
Can anyone please help me? I am not from the development team.
Thanks & Regards,
Manzoor Alam
Hi Manzoor,
This is not my strength either, but take a look at this article:
You might try contacting JWME support directly as well if you don't get it to work. David and the crew there are fantastic!!
