Unable to Close Sprint
Daniel Zimmerman
I created a separate sub-task workflow that only includes 4 status values. There are two that show as green values to indicate final status ("Cancelled" and "Done - Complete"). However, now when I try to close the sprint, I get a message that the following issues have sub-tasks that are not closed. When I go to the issues in question and review the sub-tasks, they all appear to be in the Done - Complete status.
Is there some other way I need to identify the sub-task Done - Complete status = closed?
What gives? I cannot seem to identify what needs to be done to close the sub-tasks?
4 votes
Ollie Guan
August 7, 2018
Hi @Daniel Zimmerman,
Dose these 4 subtasks contain both “Done - Complete” and "Cancelled" statuses?
You can try to check the column management in the board configuration. Both of these final states match the Done column?
Daniel Zimmerman
Thanks @Ollie Guan. The column was already setup as such. After trying again the following day, it allowed me to close the sprint. I did republish the workflow, but I can't see how that would have fixed the problem. Either way, it works now.
云霄
October 6, 2023
 Thank you!!  After studying all day, I didn't think it was so easy
Rahul Ingle December 2, 2021
@Ollie Guan  Thank you solution. my issue has been resolved.
Ina Hemmes February 18, 2020
This answer solved my issue also. How simple can it be!  Thank you!!
