I set up an Application under my GitHub Orgnization to retrieve my oAuth Client ID and Client Secret. (I used "https://{myid}.atlassian.net" as the two URLs that need to be specified for the Application.)
When I go to "Manage DVCS Accounts" and attempt to link up the GitHub Application with the JIRA DVCS connector using my GitHub Organization name, Client ID and Client Secret, I get the following error:
Invalid credentials, please reset OAuth settings
I tried resetting it on both the JIRA and GitHub sides, but no luck.
Could you please help?
The issue has been fixed in the 1.4.3 version.
Miroslav, I just tried again and got the following error:
Failed adding the account: [Error retrieving list of repositories]
I tried and got the same thing....3 years later
In JIRA 5.0 do not have an upgrade of the plugin. How to do in this case? Because that error is the same we have here, but in JIRA 5.0.2.
the last one supported to JIRA 5.0.2: 1.4.0.1
Great Mrs. Stencel. Now it's working.
Thank you for the quick upload the 1.4.0.2 version.
How exactly would you go about manually updating the plugin? I tried replacing the old one and removing the .osgi transformed one and then starting up jira again. But it still shows the old version...
Chris, we asked Atlassian to upgrade our DVCS connector to 1.4.3, and now everything's working great.
Manually updated, had to go to the version history page as it was not listed in the add-on marketplace by default. Once manually updating all was well, thank you.
It might be that the access token was rewriten with a wrong value. You must regenerate access token on the account. To do this:
I've tried this but no luck.
I receive the following when adding it fresh
then if I refresh the page and try to refresh the repos i get
Error when refreshing account 'xxxxchris'.
Attempting to regenerate the access token does nothing but refresh the page.
This appears to be a new issue that is currently being reviewed. Sorry I don't have more details for you except to watch this issue for updates: https://jira.atlassian.com/browse/DCON-324
Hope this helps!
Read the story
