Unable to create a board for existing project
Chris Sim
July 6, 2018
I'm unable to create a new board for any existing projects, it keep showing
  • You do not have permission to share. All shares are invalid.
  • The user 'username' does not have permission to share. The owner has not been changed.
I'm already in administrator role for our jira cloud account and project lead for the project.
Yogesh Mude
July 6, 2018
HI @Chris Sim
Welcome to the community!
I think you don't have  Create share Object permission.
please have a look at the below KB.
https://confluence.atlassian.com/jirakb/when-creating-a-jira-software-board-the-error-you-do-not-have-permission-to-share-all-shares-are-invalid-is-displayed-779160905.html
Tom Auger May 27, 2020
Please check whether this information is still accurate. I cannot find "Create Shared Object" anywhere within the dashboard.
Like • 3 people like this
Ramy June 23, 2020
The same here :( As @Tom Auger said, I wasn't able to find it too!
stucampbell
@Chris Sim I'm on Jira cloud and I can't find a Create Shared Object permission either.
If anyone has any pointers that would be great. Thanks!
Like • 4 people like this
Omar Ez Eddin
November 8, 2024
Hello, I am having the same problem.
what I did was:
1. created a new scrum board
2. added a new field to stories
3. started the first sprint
4. on the next day now one was able to see the boards or access anything
Atul Patil October 27, 2020 edited
Hi @Tom Auger @Ramystucampbell,
If you have Jira administrator access, then please check which group you are part of from user management.
Once you get the group name, then System > Global permission
Go to bottom of the page and select the permissions (Create shared object) and group(you are part of).
This will make sure the user part of that group will able to create Shared objects like board.
If you do not have Jira admin access, then please share this info with your Jira admin.
Cheers.
Atul
Dhouha Kallali October 29, 2021
Hi, Everyone
I'm an Administrator on a JIRA Cloud.
I faced the same issue, but unfortunately I cannot find the (Create shared object) even following instructions you mentioned above.
Can you please help on this ?
Thank you
Best regards
Atul Patil October 29, 2021
Hi @Dhouha Kallali ,
On Cloud I checked it should be Share dashboards and filters permission.
Please try it.
Regards
Atul
Like • Andreas Abrahamsson likes this
Dhouha Kallali November 22, 2021
Hi Atul,
Thank you for your reply. It works
