×Hi All
I have some users on an Apple device (iMac/Macbook) where the drag and drop function does not work. The function works fine on any of the windows devices.
Example:
You have an email with an attachment and you want to drag and drop the attachment into a ticket from the customer portal or the agent portal.
Similarly - you want to be able to drag and drop from a folder location onto the relevant attachment fields when logging an issue.
Hi @Robin Stemmers,
I am using a MacBook myself and have no issues with drag and drop. Are they using any browser in particular? Can they use different browsers to check if it's linked?
Best,
- Manon
Hello Manon
They are using Chrome as that is the preferred brower in our org.
I will check with them in terms of another browser, but more than one user could not do this action
