Unable to fetch data using API - Search/jql
Chandra Kakkireni March 21, 2025
Hi Team,
Previously we used api/2/search to fetch data but it was deprecated. I tried accessing api/2/search/jql api but its not returning any data giving 200 success status but empty array.
Please let me know what i am missing
curl --location 'https://{instance}/rest/api/3/search/jql?jql=issuetype%20%3D%20Epic%20ORDER%20BY%20created%20DESC' \ --header 'Authorization: Basic {api token}' \
5 accepted
3 votes
Thank you all. Issue was identified with help of Atlassian support team. Issue with Service account which i am using to get the data. Actually status was  confused me as it returning statuscode=200 and empty array
David Nickell
March 21, 2025
A couple of ideas:
  1. Based on the JQL I see, you may simply need to use the URL Friendly version shown in your browser instead of the text with spaces in the JQL String
  1. Have you tried running your search URL/endpoint from a browser (e.g. Chrome)?
  2. have you tried running a "myself" endpoint just to be sure your API Token has been properly encoded?  (the 200 status code would indicate that's not the problem).
If you can see the issues in Issue Navigator (eliminating any concerns about permissions), and you are getting a 200 status code -- I'm betting its the format of the JQL.   You can also do another test by using a filter Id  - e.g. search?jql=filter=99999.
Good luck
Mahesh Shinde
March 21, 2025
Hi @Chandra Kakkireni ,
Please, find the attached document link which will correct way to perform the search using JQL.
https://confluence.atlassian.com/jirakb/how-to-return-issues-from-a-jql-query-using-rest-api-1289424308.html
Let me know if you have any issues.
Mahesh Shinde
Hi Mahesh, i have followed same instructions exists in link, but no luck.
Previously we used to get the data using api/2/search but that api was deprecated.
Mahesh Shinde
March 21, 2025
You are using Basic Auth where I can see token in postman page but username is missing, Can you check if you have added your user account in basic authentication?
Please, let me know if that's resolves your issues.
Mahesh Shinde
Vishal Biyani
March 21, 2025
@Chandra Kakkireni
Try something like this.
curl --request GET \ --url 'https://your-domain.atlassian.net/rest/api/3/search/jql?jql=project%20%3D%20HSP&nextPageToken=%3Cstring%3E&maxResults=100&fields=key,summary' \ --user 'email@example.com:<api_token>' \ --header 'Accept: application/json'
Hi Vishal, I have tried with user header , but no response from JIRA.
Status : 200 OK
{"issues":[]}
Vishal Biyani
March 21, 2025
Try with these 2 changes
  • remove &nextPageToken=<string>
  • Add --header 'Authorization: Basic ...' instead of --user flag
Thanks Vishal for your reply.
Initially I have tried this approach only, but didn't get any data for below as well.
curl --location 'https://instancename/rest/api/3/search/jql?jql=project%20%3D%20%22CEE%22%20AND%20issuetype%20%3D%20Epic%20ORDER%20BY%20created%20DESC' \
--header 'Authorization: Basic {apitoken}' \
Vishal Biyani
March 21, 2025
please add below 2
--request GET
Vishal Biyani
March 21, 2025
This is my working curl. replace <your instance> and <encode_token>
This should work
--url 'https://<your instance>.atlassian.net/rest/api/3/search/jql?jql=project=CEE%20AND%20issuetype=Epic&maxResults=100&fields=summary%2Ccomment&expand=name' \
--header 'Accept: application/json' \
--header 'Authorization: Basic <encode_token>' \
--header 'content-type: application/json'
Hi Vishal, I have used same in postman but no luck.
The Problem was it giving empty array, same JQL giving data at JIRA website level.
Vishal Biyani
March 21, 2025
can you show the screen shot of your params?
Vishal Biyani
March 21, 2025
and make sure body is empty.
Yes body is empty, and in params only jql was there like below image
Vishal Biyani
March 21, 2025
in params key, value add
maxResults 100
fields key,summary
and see if it makes a difference.
When you run the curl command in unix shell or git bash shell are you getting any output?
Nikola Perisic
Welcome @Chandra Kakkireni
When you run this query in your actual Jira, does it return any results?
HI Nikola, Yes i copied the jql from JIRA itself. There it is returning data but from postman returning empty array
Help us plant more trees
