Earlier we used to use import test option under Zephyr squad but it's not coming now and having trouble with uploading test cases. Is there any alternate way to import test cases to Jira
Hi @Subaramani, ManiKandan (SP)
Go to your project in Jira.
Open the Apps menu -> Zephyr Squad -> Import Tests.
If you don’t see the option at all, ask your Jira admin to check if your project role has "Create Issue" permissions in this project.
Hope this helps!
Regards
Rajat
Hi @Rajat Pratap Singh _DHL IT Services_ , Thanks
Yes I checked on Zephyr Squad but Import tests is not showing, it was there before but later this UI got changed after that it's missing.
So, should I check with Jira admin to see we have Zephyr import permissions ??
We have exact same issue and import tests option is no more coming. Where this has been moved?
