Unable to move through workflow on jira issue
Logan Clemons
We were experiencing serious issues with Jira last week due to problems caused by a scriptrunner script field. We found the script field that was affecting our instance and removed it. But during our troubleshooting, all the issues that were created during that time appear to be corrupted.
 Capture.PNG The issues in question are missing the workflow tabs, so we are unable to step these issues through the workflow. Many of them are also extremely slow to load. Could this be solved with a reindex, or is the problem more serious?
Mikael Sandberg
Does your workflow have a condition for the scripted field that was removed? One thing you could try is to make a copy of the workflow, change your workflow scheme to use this new copy of the workflow and see if that helps.
Learn more
