I have a power user that relies heavily on automation within her space. She has built out two automation rules (show in image above) that she is needing to enable. The second one (Group 2) is able to be enabled without a problem. However, when attempting to enable the first (Group 1), we get the following error:
I ran into something similar earlier this week.
I deleted the trigger and added it again... that did the trick.
Make a copy of the rule first and then give it a try.
Rules can get "glitched" by too many edit / publish cycles, or incompatible settings that are not resolved by the editor. Apparently something gets broken in the JSON behind the scenes, although I have not found any public backlog defects listing the symptom.
Typically the two ways to check for that are:
The other symptom I noted in my earlier post was related to the validation changes and not the existing problem with rule "glitches".
Quite recently, additional validation was added to the automation rule editor. When changing a rule, it is possible it cannot be enabled when it contains errors...but it can still be saved.
I wonder if that validation is now checking when trying to enable from the rule list. Perhaps this rule has errors that can be seen if one opens the rule in the editor and tries to enable it from there.
If that does not help, please post an image of the complete rule to provide context for the community to offer suggestions. Or, contact the Atlassian Support team to take a look: https://support.atlassian.com/contact/#/
