Unable to retrieve project list using PHP example in docs. Library does not exist at given URL.
Andrew Turner
October 15, 2020
I'm trying to retrieve a list of projects using the API GET /rest/api/3/project/search and connecting via PHP.
The API docs show a PHP example using something called the Unirest library and give a URL of http://unirest.io/php.html however, the library does not exist at that URL or even at that domain.
Anyone know how to make a PHP connection with/without this library?
Docs link:
Get projects paginated
Hana Kučerová
Hi @Andrew Turner ,
welcome to the Community!
I believe it is this library. Basically you just need to send a cURL request. The library provides you the possibility to create and send the request easily without much work, you just need to specify the request URL and the headers.
Register here ⬇️
