Unattended upgrade of JIRA with modified/added/removed files
Gaël NEUEZ
Hello
I'm trying to script an unattended upgrade (not a fresh install!) of our JIRA instances.
The response.varfile is not a solution because it does not take into account all params.
I started at first to feed to answers to the installer like this:
cat << EOF | ./atlassian-jira-software-${TARGET_JIRA_VERSION}-x64.bin
o
3
/opt/atlassian/jira
n
y
u
n
EOF
where the blank lines correspond to the "pages" of modified/added/removed files that you need to confirm before reaching the "real" upgrade question...
But my concern is that depending on my JIRA instances, the number of modified/added/removed files (compared to initial install) is not fixed (some may have no changes, some may have dozens of modifications).
This means I cannot get this script generic enough. I've tried to used the "expect" linux command to try the same thing :
spawn /tmp/atlassian-jira-software-${TARGET_JIRA_VERSION}-x64.bin
expect {
"This will install JIRA Software" {
send "o\r"
exp_continue
"Choose the appropriate installation or upgrade option" {
send "3\r"
exp_continue
"Existing installation directory" {
send "/opt/atlassian/jira\r"
exp_continue
"Back up JIRA home directory" {
send "n\r"
exp_continue
#THIS IS FOR sending return to each page of modified/added/removed files
#Each time we have a page, send return
"\[Enter\]" {
send "\r"
exp_continue
"Have you completed all these steps" {
send "y\r"
exp_continue
"Upgrade \[u, Enter\], Exit \[e\]\r" {
send "e\r"
exp_continue
But with no luck either, because it seems those pages are not exactly catched by the script.
Has anyone already been able to handle this upgrade in unattended mode?
Or is there a way AHEAD of calling the script to know how many modified/added/removed files there are in my instance?
Regards
Asif Khan
June 25, 2020
I had the same issue with Confluence unattended installation, per Atlassians they have no plan to fix or implement this feature in near future. Don't use it for any Atlassian products
SERVER
Register Now
