Under "details" in an issue on Jira Cloud, I am unable to change an outdated URL in one of the fields. I have given myself administrator rights but still cant
Hi @Angus Smith
Based on screenshot shared, If you are not able to update, there could be reasons as below:
Hi Piyush, I gave myself "team member" rights which "permissions" tells me I have the rights to edit with, but I still get a picture of a padlock...
Can you share the padlock screenshot?
This is issue security, which doesn't have relation with the field update.
Issue security, denotes granular access/view for a issue specified for users based on roles/fields/assignee/reporter.
Issue security doesn't adhere any edit permission changes.
Ref. Issue security - https://confluence.atlassian.com/adminjiraserver/configuring-issue-level-security-938847117.html (this is data center information, implies to cloud as well)
You need to look if the field is in the edit screen
Hi Mohamed, I gave myself "team member" rights which "permissions" tells me I have the rights to edit with, but I still get a picture of a padlock...
You need to check you screen scheme and see if the field is in the edit screen
Ok, so just look at the screen configuration Manage work item screens | Atlassian Support
I think that the field is missing in the edit screen
