Unexpected error executing rule : Rule to stop tickets from being closed when no hours logged
Lupita de Alba
October 16, 2025
14/10/25 03:56:29 am (53359684)
FAILURE
0.27s
Action details:
JQL condition
Unexpected error executing rule:
org.eclipse.gemini.blueprint.service.importer.ServiceProxyDestroyedException: service proxy has been destroyed
Associated items:
Issue event
Trudy Claspill
Hello @Lupita de Alba
Is this an error that keeps occurring each time the rule runs, or did it happen only once?
Can you provide screen images of the entire rule, please?
Lupita de Alba
October 21, 2025
The rule run success today, below appear the direct link to the Audit-log and the Automation description, please review and let me know if you need any other help for this investigation error
https://jsw.ibm.com/secure/AutomationProjectAdminAction!default.jspa?projectKey=PES#/rule/8637
https://jsw.ibm.com/secure/AutomationProjectAdminAction!default.jspa?projectKey=PES#/rule/8637/audit-log
Trudy Claspill
We will not be able to access the information in the links you provided. We are users of our own Jira systems and don't have access to the system you are using. We will need you to copy the information from your system and paste it here.
Like Gor Greyan likes this
Gor Greyan
October 17, 2025
Hi @Lupita de Alba
I agree with @Trudy Claspill
If you can, please provide entiry rule.
Also, I found this article about that error.
https://support.atlassian.com/automation/kb/all-rules-are-failing-to-be-executed-due-to-the-error/
Also, if you want to reopen non-logged ticket, you don’t need JQL at all. Use smart-values instead (no indexing/JQL service needed).
  • Trigger: Issue transitioned → To status: Done (or your terminal status)
  • Condition (Advanced compare):
    {{issue.timespent}} equals 0
  • Actions:
    • Transition issue back to In Progress
