I tried to import an export from our local JIRA to OnDemand. Files are available in our WebDAV directory. Everything worked fine until the very end of the import, where I got a JIRA Import Wizard - Error page stating:
Unexpected error while restoring data: java.lang.NullPointerException
Got a response from Atlassian's support. I had run into the bug https://studio.atlassian.com/browse/JST-5641. They helped me to clean up my data and re-imported it. Now it seems to work!
i got a similar error, i've created a ticket here: https://support.atlassian.com/browse/JST-26988
We need to see more of the error than that. Java's default error is NPE when it's not been told a specific error to throw. We need the handful of lines immediately before and after that (not the 1000s of lines it's probably thrown at first though - just start with a couple of lines before and 5 after)
Since it's OnDemand I don't see more of the error than this. However, I just noticed that even though I got this import error there are some data imported, like issues and projects, but not avatars and attachments. When I browse the UI I see some errors occationally and the UI seems a bit messed up. For instance, I now only have an "Issues" tab, no "Wiki" etc...
Did you copy the attachments and avatars to webdav too?
While importing JIRA there is a select box to choose such backups, as JIRA xml backups don't come with attachments.
Yes, I did copy attachments and avatars, and chose those while importing.
Register today
