When I check for errors, everything shows a green check mark. However, on the review screen, one error is listed, but I cannot find the error that it is requiring me to correct. When I click on the link to review and correct errors, it takes me back to the checks, which have all passed.
I am unable to contact Atlassian Support because we are on the "Starter Version" of Jira Software Server. However, our cloud instance is Jira Software Standard.
That's a great suggestion. I'll give that a try.
Thank you.
Fantastic! That appears to have solved the issue!
Thank you so much, Alex!
What happens when you click on the "View Errors and Warnings" link ?
That's in the poster's original post:
Right... The other thing I can think of trying is just clicking on Run if it allows them despite the errors. They might have to look at their logs to see what errors they are getting there.
The "Run" button is greyed out so, unfortunately, I cannot move forward. The only items shown in the pre-migration logs are under the "Requires attention_Pre-migration report" where there are 6 items referenced as "Unsupported" due to the fact that they are a "Custom event type". The report then states that this is not supported via migration, however, under "Next steps", it states "If you require this field value, use a csv import to update the issues post migration."
It does not indicate, to me, that it is something that would prevent the migration from moving forward.
@Mike Freeman yep I can confirm that the content in the pre-migration report delivers the detail on what will/will not migrate, but it will not prevent the migration moving forward.
Then, I have no idea how to move forward with this. It's highly frustrating that Atlassian is forcing us to migrate to the cloud in order to avoid the risk of end-of-life software on our network, but they refuse to help just because we have a "starter license". You would think that there would be some consideration of the fact that our cloud version is Jira Software Standard and not the free tier.
Hi @Mike Freeman, I saw your comment and wanted to try to offer a workaround.
I'm not able to test this, but are you able to submit a support request if you select "Continue without SEN" and "Continue without URL" in the support contact form?
I've also flagged your issue with our migration tooling and support teams to see if they can help.
Thank you. That worked...I was able to submit a support ticket. In the past, I was unable to do this because I would only put that we were migrating ten users. However, I had forgotten that we are actually migrating more than that because we have grown since we purchased this license and actually have twelve users to migrate, as we rotate a couple of those users in and out of activation status.
What version of JCMA are you using? If you are not using the latest version have you tried upgrading to the latest version of JCMA?
The current version of the Cloud Migration Assistant is 1.7.7. I updated the tool before running the migration checks.
