I am working on changing a projects workflow. In the Board settings -> columns the unmapped statuses have many duplicates. For example To Do shows up 7 times.
I want to remove the list of duplicates.
Hii @Adam Bang Does your board filter contain issues from multiple projects? If yes, are those projects team-managed projects? Please note that this is a side effect of the use of team-managed projects when creating a multi-project board.
@Adam Bang It sounds like your instance may have multiple 'To Do' statuses and each workflow applicable to your board is using a different one of these statuses.
The best option would be to remove all of the duplicates from your environment, but that could have impact to other teams/processes.
The next best option would be modify the workflow for each of the impacted issue types and ensure you're using the same status by the status ID.
