Unstable Automation Rule for Assigning Task Assignees Based on Epic
Nguyen Thanh Tien
I created an automation rule "When Parent Assigns to a User, Change Assignee of All Children Accordingly," as shown in the attached image.
However, this automation runs inconsistently; it sometimes works and sometimes fails, as indicated in the audit log below:
- Unsuccessful
- Successful
Does anyone have suggestions on how to resolve this issue?
2 accepted
Rilwan Ahmed
Hi @Nguyen Thanh Tien ,
Welcome to the community !!
There is clear information in the screenshot you attached. You need to uncheck the option "Only include issues that have changed since the last time this rule executed" in your automation rule for branch condition. Example screenshot attached.
Manoj Gangwar
Please try changing the branch type, from "Children" to "Stories (or other issues in Epic)"
Nguyen Thanh Tien
I've tried changing the branch type, from "Children" to "Stories (or other issues in Epic)" as @Manoj Gangwar 's advise and uncheck the checkbox as well as @Rilwan Ahmed 's adivse. And It works normally now. Thank 2 guys for your support!
Nguyen Thanh Tien
Hi @Rilwan Ahmed , I don't see the checkbox you mentioned from my view. It seems that it does not apply to the related issue 'Children' in my automation rule.Screenshot at Sep 04 18-14-37.png
Rilwan Ahmed
Did you create rule in Global automation section ? This option is not present there.
Create the rule in project settings --> Automation if the rule is related to single project.
Nguyen Thanh Tien
I created this rule within a team-manage project (not apply for global).
Register today
