Good afternoon,
We are currently facing an issue with automation. Let say we have an issue type named "Project" and an issue type named "Epic".
We create a Project with the 3 fields filled out. Then, we create the child of the project (= Epic): The Epic takes all the information from the Project (Priority, Component/s, Fixversion/s).
When the Project update a field, the Epic should also be updated. HOWEVER, sometimes the child will have different information from the parent.
Meaning, the Epic can have a different FixVersion/s from the parent. So, if the Priority is updated on the Project, the Epic should only have its field 'Priority' updated not: Component/s and Fixversion/s.
What we currently have with Automation Rules:
With this process, if ONE field is updated for Project ALL the field are updated for Epic.
What I thought could be possibly done:
Thanks for your returns and ideas.
I would go with 1 automation per field with a good naming convention to make it easier. Try to manage the 3 level within the same automation with If Then Else condition.
Having multiple automation do not really make it harder to maintain as each automation will be simpler.
Regards
