We have a number type custom field (10701) that represents days and would like the original estimate field to be updated when this custom field is edited.
I've tried using the 'Set value' operations, but I can't get they to work.
Please can anyone tell me if there is something wrong with the way I have structured the following scripts:
{{triggerissue.CustomField_10701}}
or
{{triggerissue.CustomField_10701}}d
or
{{issue.CustomField_10701}}d
or
or
{ "fields": { "timetracking": { "originalEstimate": " {{triggerissue.CustomField_10701}}d"} } }
Fails:
What kind of field is this? Is this a text? If yes then you have to convert it to a number and then use the smart value formula. I would use something like the following:
{{issue.fields.CustomField_10701.asNumber}}d
Try the above and let me know if that works.
Is this a Number Field
The checkbox "Allow rule trigger" helped me
Thanks)
