Update a custom field in a view screen
Sara
I've created a new custom field, type checkbox with default value yes, and add it to the create and view screen, the field is showed fine but I can not edit it. I need that the field was editable, can you please help me?
Thanks in advance.
2 accepted
Mohamed Benziane
April 24, 2020
Hello @Sara
Can you make sure that the field is on the "Edit screen" of your screen scheme. On your screenshot it seems to be added to the "View screen".
Hope this helps
Sara
I added and works thanks. Was only on the view screen not in the edit one.
Monika Rani
April 24, 2020
Hi @Sara ,
I have created the same but I am able to edit it. Can you please share your screenshot?
Sara
Custom field configuration:Captura de Pantalla 2020-04-24 a la(s) 9.36.23.png
Example issue view (the same in old and new view, not editable): issue.png
Configuration screen (is added):
Monika Rani
April 24, 2020
@Sara  can you add the same custom field to the edit screen too and check after that.
Sara
That's it! works thanks
