×I have a custom field called due date. I want to auto-fill it to 2 weeks from the date the issue is transitioned to a particular status. Is this possible?
Hello @Nischal Sharma
You need add-ons for implementing this feature. You can use Automation, Script runner or Power scripts or JSU. Multiple options are available.
I personally use Script runner quite a lot and if you use Script runner then here is an example explaining exactly what you need to do.
https://community.atlassian.com/t5/Jira-Core-questions/Automatically-Set-Due-Date/qaq-p/240779
issue.setDueDate(new Timestamp((new Date() + 14).time))
Here 14 is the number of days i.e. 2 weeks.
As Tanya eluded, you would need an addon to perform the ‘calculation’ portion of you requirement.
Hi Nischal,
Yes, this is possible using a post function. You should edit the workflow and add this on the relevant transition.
I guess to implement this kind of calculation you would need to use script runner abilities and write a script that will implement this requirement.
If you need any assistance with that you are welcome to PM me 😊
Tanya
