Good morning community!
I've been working on a new workflow an I have built a transition that includes a validator for a regular expression check. I would like to allow a selection of options so I believe that the best choice is to use "Regular Expression Check" . I have tried what appears in the picture below but is not working, it gives me an error.
Can anyone help me with this? Am I using the right expression?
Thank you in advance!
Mario
@Mario Palacios Fernández It's wrong mentioned on the page.
Regex would be : (Small|Large|Xtra Large)
Each value separated by pipe |
Eg : (Done|Not done)
Hi!
Now it works! thank you so much!
So it is wrong mentioned on the info panel on the page?
Mario
Yep, on info panel it's wrong. comma (,) doesn't work as OR operator in Regex.
