Update summary with custom fields
Salih Zengin November 4, 2021
Hey,
I already read a few articles, but didn't find anything which fits to my scenario.
I want to create an offboarding workflow. In the service request I have 2 custom fields, date and name.
now i want to set the summary to date - 'offboarding' - name.
I read, i could something with post functions but didn't figure out how.
I need one example to understand.
Who can help?
Mikael Sandberg
Hi @Salih Zengin,
Instead of using post function you use Automation and smart values to set the summary. The value for the summary would look something like this:
{{issue.date}} - offboarding - {{issue.reporter}}
Salih Zengin November 9, 2021
But it is not the reporter. reporter is mostly someone from HR.
But i have a customize field called newjoiner.
Can I use also smart values with custom fields?
Mikael Sandberg
Yes, you can use any field as part of smart values. So for your field it would be {{issue.newjoiner}}
I did it with the ID. works, thanks. Awesome :)
Julia Shcherbyna _SaaSJet_
Hi @Salih Zengin if you are interested in organizing an efficient offboarding process this article can be useful for you
Employee Offboarding in Jira: How to avoid missing anything?
Matthias Gaiser _K15t_
Hi @Salih Zengin ,
welcome to the Atlassian Community.
You can try to accomplish that with Jira Automation:
  • Create an automation rule
  • Add a condition that it only applies to the cases you want
  • Add an „edit issue“ action and update the summary accordingly. You might want to use smart values for this.
Does that help / sound like a good solution to you?
Matthias
Register now
