×We use MS Teams channels to show important notifications from Jira automation, and this has worked fairly well for a year or so. Now Microsoft has announced that they change the webhooks, and last week started to display a warning message that the webhook URL needs to change no later than 31 December.
So I updated the URL, created new webhooks and updated the Jira rules with this new information.
And then the notifications stopped coming.
From Jira point of view, everything looks ok, the audit log shows success. (I attach a simple test to illustrate)
Is there a known problem in Jira automation to use the new Teams webhook URLs? (far-fetched perhaps)
Have anyone else in this community encountered this? Found any way to fix this?
I'm also having this issue. After I updated the webhook url, it does not work.
Didn't find any solution so far.
Using curl to test the POST part it works:
curl -H "Content-Type:application/json" -d "{'text':'Hello World'}" <webhookurl>
Just verified my newly created webhooks like suggested above, and that worked just fine for me too. Great tip, @Lefteris Spatharakis !
I've found a workaround now, somewhat functioning.
Instead of normal Teams webhooks, I have to use teams Workflows. So I have created one following these steps (see below) to get an URL to paste into Jira automation rule. And it works, but with the following drawbacks:
1. Can only use public channels now, no longer private channels
2. Sender of notification is no longer 'Jira Automation', it's the personal user account which created the workflow
Steps:
The channel postings will look something like this now:
@Niklas Malmberg Thank you
Can you please share how you have configured on Jira the Message title and Message so that links are displayed?
Mine does not display links and I would like that the card would allow for the issue link to be clickable.
Here is mine.
In your rule part that send messages to Teams, this line
Issue: [ **{{ issue.key}}** ] ( {{issue.toUrl}} ) _{{issue.Summary}}_
will result in a line in Teams that will looks something like
** makes the text bold
_ makes the text italic
[ key ] (URL) creates the clickable link
Thank you. Manage to address my issue.
I just tried this but it is not working like yours shows.
In my message body I have:
{{#lookupIssues}}
[ {{issue.key}} ]
( {{issue.toUrl}} )
{{/lookupIssues}}
And my Teams channels receives the following:
@Robert Banister I suggest you try to 'debug' your rule, make it in smaller chunks and send each statement to the audit log (Log action component) to see why it does not behave like you want it to.
My money is on the lookupIssues which I find somewhat difficult to use :)
Ps
Different Jira versions seem to have slightly different syntax and feature sets for automation rules. At least - based on community postings - that's how I understand the situation.
I am having the same issue. Weirdly the Audit Log in Jira automation tells me messages were successfully sent to Teams...but they weren't.
Has anyone found a solution to this problem yet?
Hi guys,
so i am having trouble setting the automation rule up in the fist place :(
I have created the Teams Workflow for posting to a channel when recieving a incoming webhook.
Copied over the URL, added it to the Jira Allowlist (both checkboxes are unchecked).
Diffrent from your Screenshot, by now I have to create a "Secret Key". Did that, gave it a name and posted to URL.
So, when creating a new rule, after selecting the action "Send Teams Message", i can select the Key with the webhook url.
And from here I'm stuck.
"Please enter a valid MS Teams webhook URL"
What did I miss?
Best regards
Max
Unsure what you have done, but that does not look like any URL (Uniform Resource Locator, an address on the web) I've ever seen before.
Mine looks like https://prod-148.westeurope.logic.azure.com:443/workflows/4862f5c7c7114c2597cb7.....
Hi, it looks thtat way because Jira wants me to create a Secret Key. This is just the name for my Webhook URL.
And I did try to just paste the URL in the name field ;)
When picking the action, i am presented with a Dropdown menu, from which I can choose the key.
Thank you very much
Best regards
Max
Hi @Max S,
can you please share to which version you had to update to get it to work? We're experiencing this problem on a Jira Data Center V 9.4.30 with Automation for Jira V 9.0.3 right now.
Or do you have the link to the bug ticket, where this is addressed?
Thank you!
Here's an example of the warning message displayed, urging us to update the webhooks
Link to Microsoft info around this topic:
https://learn.microsoft.com/en-us/microsoftteams/m365-custom-connectors#update-connectors-url
