Updated date - dependency
Rafal Skrzeczkowski March 4, 2025
I wonder which changes have and impact on field "upadated". For example: does linking two issues (related issues) changes this field?
Is there any list of events that trigger this field?
Karan Sachdev
March 7, 2025
Hey Rafal,
The "updated" field contains the timestamp when the issue was last updated, which includes any field updates, status change as well as issue linking.
This field will also be updated when an issue is linked to another issue, or if it's parent issue is added/removed/changed.
From the UI, it's visible on the bottom right (after the context fields) along with the issue creation and resolution time.
Rafal Skrzeczkowski March 10, 2025
Great! Thank you :)
