Updated "Epic Status" from Done to To Do is not reflected in Epic issue view
Brian G
When I update the "Epic Status" (not issue/workflow status) from Done to To Do, the Epic issue view still shows "(green checkmark) Done".
I verified that the epic status was updated correctly:
How can I either hide this or show the updated/correct Epic Status?
I have already removed "Epic Status" from all views.
Fernando Bordallo
January 17, 2020
Hello @Brian G
This I believe is a probable bug. Can you open a support ticket for this?
https://support.atlassian.com/jira-software-cloud/
