I have two different workflows enabled for a project for three different work types:
Bug & request share the same workflow, while build has it's own. My goal is to update the workflow for the build tickets so they can have unique statuses for a different team. Anytime I update one workflow the changes are automatically applied in the other.
Is this a bug? Do I have an improper config?
Thanks in advance.
Hi @Luke Burns
Welcome to the community.
You will need to create new statuses in the workflow for work item Build, if you rename a status, this effect any workflow where this status is also used.
