Clicked on Download and started install,, clicked on Upgrade existing,,, then got an error that a file was open.. clicking continue and ignore multiple times,, had to quit.. now my jira installation is gone?
Jiradb in mysql is still there.
and I have JIRA-7.7.0-back.zip in C:\Program Files\Atlassian
I restarted atlassian-jira-core-7.13.0-x64.exe but it comes up a new install, not an upgrade? I completed the new install end now get.
What do I do to get Jira back up?
I ended up uninstalling 7.13 and clearing the jira folders, then un-zipping the two backup files that were created during the upgrade and restarted jira 7.7.
Ok, Glad you got it working! :)
Thanks..
so all good now,, will try upgrading again another day.
Hi Steven,
Check C:\Program Files\Atlassian\jira\lib\mysql-connector-java**.jar
If the file does not exist, download it from https://dev.mysql.com/downloads/connector/j/5.1.html
Make sure you're downloading the 5.1 version, not the 8.0 version of the connector.
