Sign up Log in
Upgrade from 6.4 to 7.0 error - cannot access jira.
Krystian Szczęsny January 26, 2017
I cannot access my installation after this upgrade :/
I've upgraded since JIRA 4 and never had any issues with it. Now I've got this in my logs, which points me nowhere:
2017-01-27 09:08:14,114 http-nio-8080-exec-19 ERROR krystian 548x44x1 crr7li 192.168.88.85,127.0.0.1 /secure/MigrationSummary.jspa [o.a.c.c.C.[.[.[.[jsp.decorators.onboarding_jsp]] Servlet.service() for servlet jsp.decorators.onboarding_jsp threw exception
java.lang.AbstractMethodError
	at com.atlassian.jira.plugin.webfragment.contextproviders.AbstractJiraContextProvider.getContextMap(AbstractJiraContextProvider.java:28)
	at com.atlassian.plugin.web.model.AbstractWebItem.getContextMap(AbstractWebItem.java:30)
	at com.atlassian.plugin.web.model.DefaultWebLabel.getDisplayableLabel(DefaultWebLabel.java:55)
	at com.atlassian.plugin.web.DefaultWebInterfaceManager$WebItemConverter.apply(DefaultWebInterfaceManager.java:306)
	at com.atlassian.plugin.web.DefaultWebInterfaceManager$WebItemConverter.apply(DefaultWebInterfaceManager.java:290)
	at com.google.common.collect.Iterators$8.transform(Iterators.java:799)
	at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
	at com.google.common.collect.Iterators.addAll(Iterators.java:362)
	at com.google.common.collect.Lists.newArrayList(Lists.java:160)
	at com.google.common.collect.Lists.newArrayList(Lists.java:144)
	at com.atlassian.plugin.web.DefaultWebInterfaceManager.getDynamicWebItems(DefaultWebInterfaceManager.java:231)
	at com.atlassian.plugin.web.DefaultWebInterfaceManager.getDisplayableWebItems(DefaultWebInterfaceManager.java:214)
	at com.atlassian.jira.plugin.webfragment.DefaultSimpleLinkManager.getLinksForSection(DefaultSimpleLinkManager.java:120)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager.access$701(ThreadLocalCachingSimpleLinkManager.java:28)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager$3.load(ThreadLocalCachingSimpleLinkManager.java:149)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager$3.load(ThreadLocalCachingSimpleLinkManager.java:146)
	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
	at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
	at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
	at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
	at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4830)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager.getLinksForSection(ThreadLocalCachingSimpleLinkManager.java:153)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager.getLinksForSection(ThreadLocalCachingSimpleLinkManager.java:140)
	at com.atlassian.jira.plugin.webfragment.DefaultSimpleLinkManager.getNotEmptySectionsForLocation(DefaultSimpleLinkManager.java:242)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager.access$301(ThreadLocalCachingSimpleLinkManager.java:28)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager$6.load(ThreadLocalCachingSimpleLinkManager.java:193)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager$6.load(ThreadLocalCachingSimpleLinkManager.java:190)
	at com.atlassian.jira.plugin.webfragment.ThreadLocalCachingSimpleLinkManager.getNotEmptySectionsForLocation(ThreadLocalCachingSimpleLinkManager.java:197)
	... 3 filtered
	at java.lang.reflect.Method.invoke(Method.java:497)
	at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:30)
	at com.sun.proxy.$Proxy421.getNotEmptySectionsForLocation(Unknown Source)
	... 3 filtered
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207)
	at com.sun.proxy.$Proxy1264.getNotEmptySectionsForLocation(Unknown Source)
	at com.atlassian.jira.plugin.headernav.HelpMenuContextProvider.collectDisplayableSections(HelpMenuContextProvider.java:60)
	at com.atlassian.jira.plugin.headernav.HelpMenuContextProvider.getContextMap(HelpMenuContextProvider.java:47)
	at com.atlassian.plugin.web.descriptors.DefaultWebPanelModuleDescriptor$ContextAwareWebPanel.getHtml(DefaultWebPanelModuleDescriptor.java:144)
	at com.atlassian.jira.plugin.headernav.ModernPluggableTopNavigation.getHtml(ModernPluggableTopNavigation.java:56)
	at com.atlassian.jira.plugin.navigation.HeaderFooterRendering$7.visit(HeaderFooterRendering.java:301)
	at com.atlassian.jira.plugin.navigation.HeaderFooterRendering$7.visit(HeaderFooterRendering.java:293)
	at com.atlassian.ozymandias.SafePluginPointAccess.invokeModule(SafePluginPointAccess.java:452)
	at com.atlassian.ozymandias.SafePluginPointAccess.descriptors(SafePluginPointAccess.java:150)
	at com.atlassian.jira.plugin.navigation.HeaderFooterRendering.includeTopNavigation(HeaderFooterRendering.java:293)
	at com.atlassian.jira.plugin.navigation.HeaderFooterRendering$1.run(HeaderFooterRendering.java:109)
	at com.atlassian.ozymandias.SafePluginPointAccess.runnable(SafePluginPointAccess.java:201)
	at com.atlassian.jira.plugin.navigation.HeaderFooterRendering.includeTopNavigation(HeaderFooterRendering.java:106)
	at jsp.decorators.onboarding_jsp._jspService(onboarding_jsp.java:252)
	at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
	... 140 filtered
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
2017-01-27 09:08:14,147 http-nio-8080-exec-19 ERROR krystian 548x44x1 crr7li 192.168.88.85,127.0.0.1 /secure/MigrationSummary.jspa [o.a.c.c.C.[Catalina].[localhost].[/]] Unhandled exception occurred whilst decorating page
java.lang.RuntimeException: javax.servlet.ServletException: com.google.common.util.concurrent.ExecutionError: com.google.common.util.concurrent.ExecutionError: java.lang.AbstractMethodError
	at com.opensymphony.sitemesh.webapp.decorator.BaseWebAppDecorator.render(BaseWebAppDecorator.java:37)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:92)
	at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:112)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	... 109 filtered
Caused by: javax.servlet.ServletException: com.google.common.util.concurrent.ExecutionError: com.google.common.util.concurrent.ExecutionError: java.lang.AbstractMethodError
	at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:908)
	at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:837)
	at jsp.decorators.onboarding_jsp._jspService(onboarding_jsp.java:276)
	... 26 filtered
	... 117 more
Caused by: com.google.common.util.concurrent.ExecutionError: com.google.common.util.concurrent.ExecutionError: java.lang.AbstractMethodError
	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2201)
	... 3 filtered
	... 3 filtered
	... 146 more
Caused by: com.google.common.util.concurrent.ExecutionError: java.lang.AbstractMethodError
	... 191 more
Caused by: java.lang.AbstractMethodError
	... 205 more
2017-01-27 09:08:14,154 http-nio-8080-exec-19 ERROR      [o.a.c.c.C.[.[localhost].[/].[action]] Servlet.service() for servlet [action] in context with path [] threw exception
	... 109 filtered
	... 26 filtered
	... 117 more
	... 3 filtered
	... 3 filtered
	... 146 more
	... 191 more
	... 205 more
Any tips? :/
Krystian
I had to remove all of the plugins from $JIRA-HOME/plugins/installed-plugins
Previously I have only removed the ones which were not from atlassian, after removing everything and running the installation process again it finally woke up... phew.
Gonchik Tsymzhitov
February 26, 2017
Thank you for advice.
It has really safed my time.
