I want to upgrade jira form version 6.3.6 to version 7.6. Please suggest upgrade path for the same.
I am planning to follow below upgrade path:
6.3.6 -> 7.0
7.0 -> 7.6
Thanks.
Hi there,
are you using Jira with Agile? That could complicate things a bit as you'd need to go from 6.3 to 6.4, then to 7.0 and latest. (Agile needs to converts some fields automatically)
Let me know if that makes sense.
Hi Krisz,
I am going to follow this upgrade path as suggested by you and will update you with the result.
6.3.6 -> 6.4 -> 7.0 -> 7.6
Thank you so much for quick reply.
Zahabiya
Yay,
happy to hear that, I hope Production will go just as smooth.
Krisz
