I'm planning to upgrade my Jira instance running on linux from 8.1.0 to 8.13.10, so the database used is mysql 5.7.25.
So the question here is, if the db (mysql 5.7.25) is compatible with the upgrade? any changes to be done? like a db upgrade? heard 8.13 has some tls security related change.
is there anything that i have to make sure before the upgrade?
Here's a pretty comprehensive checklist of things you should look at for your upgrade process: https://confluence.atlassian.com/adminjiraserver/upgrade-checklist-966063320.html
Hi @rsam
Welcome to the Atlassian Community!!
Please check all the compatibility like weather MySQL 5.7.25 is supported for Jira 8.13.0 version and please also check all the Add-ons compatibility as well.
Mayur
