Use Automation for Jira to transition Xray Test Plans
David Vaughan November 3, 2023
Hi, can we use Automation for Jira to automatically transition an xray test plan to a "Ready to Review" status once all underlying test executions have been completed?
Laurie Sciutti
Hi @David Vaughan ~ the following worked for me.  Be sure to replace your Test Plan field ID and use your "Ready to Review" status in the transition portion of the rule and it should work for you.  HTH
SERVER
