Use automation to move a subtask to an issue
Dennis_H
Have a business project setup and I have setup an issue as a "bucket" for other issues that need to be worked on at some point. If possible I'd like it if when a user looks at the subtask inside of an issue they could change a field setting and it would move the subtask out of the "bucket" issue to a regular issue. The subtask and the issues use the same workflow. I tried via automation and it's failing with:
(The issue type selected is invalid. (issuetype))
The rule is:
When valuer changes for (the field I picked in the subtask)
and issue type = sub-task
Then edit issue fields. Change issue type to task
Is there a way to automate moving a subtask to an issue in the same project?
John Funk
March 8, 2024
Hi Dennish,
You can only do that with a Move function, and that function is not available with Automation. You must do a manual Move.
Trudy Claspill
March 8, 2024
Hello @Dennis_H
It is not currently possible to use the Edit Issue action to edit the issue type of a Sub-task issue to convert it to a standard level issue.
Fabian Lim
March 8, 2024
Register Now
