User Picker in Jira should include inactive users.
Aravind Koushik Gobburu
User Picker in Jira should include inactive users. How to do it in Jira software.
Yevgen Lasman
January 21, 2021
There is a suggestion JRASERVER-59132 opened in Atlassian Jira which you can comment & watch. At the moment out of the box Jira doesn't support this and I am personally finding this a proper behaviour model as it doesn't create a confusion like mentioning inactive users or assigning anything to them.
Maryana Osipchuk January 22, 2021 edited
user picker select all active user even if they disabled to login in jira. You can disable users as remove them from all groups but keep active. Account will be disabled but user will be still available in user picker
Jack Brickey
Dirk Ronsmans
Right now a user picker is by default filtered only on active users:
image.png You could try putting in a role or group there and see if that works then.
Carlos Faddul
January 21, 2021 edited
What would be the need to choose inactive users? They couldn't act on issues
There are workaround solutions in this regard that could be used, if it is not necessary to take actions on the issue.
Dirk Ronsmans
Well it's not always for them to act on. sometimes its as metadata.
I have the same problem with a JSM project where we have them as watchers or metadata fields and it blocks you from editing the issue once they are inactive
https://jira.atlassian.com/browse/JRASERVER-70506
Like Jennie Juneau likes this
Pero Medic July 30, 2023
In case you need to reactivate inactive users again. You want to be able to select only the inactive users in that case and not all the employees of the company, especially if the company has and had many employees.
