User Stories Not Showing Under Epic in Advance Roadmap
Trina Woodworth September 21, 2020
I have two user stories under an epic.  When I click on the epic to view details, I can see the two user stories listed under the Issues in this epic section.  But when I'm looking at the epic in the Advance Roadmap, those stories are not listed and the icon to expand the epic section is not showing.
Expand Section Icon Not Showing.png User Stories Showing Under Epic Details.png
Sramanth Pandeti
September 22, 2020
Hi @Trina Woodworth Welcome to the Atlassian Community!
Can you check if you have these issues selected in your plan? You can go to settings -> configure -> issue sources and select the issues if you have not already.
Instructions here:
https://confluence.atlassian.com/advancedroadmapscloud/issue-sources-998651043.html
Read the story
