User can rename ISSUE_KEY
Ratom
Hi all, I'm checking existing Jira Cloud and  just found that user can rename ISSUE key !!! I
Is this really possible , I'm confused , b'z this is the key, And after exporting Jira into db there is no any traces about this event.
This is entry from History tab, I still not sure how user did this -)
Alan Dow updated key on Nov 3, 2024ABA-346  --> NDK-748
Liz Tanner
November 20, 2024
Hey there @Ratom! Quick rest assured, you are correct! Users canNOT change issue key names. But there are a couple of actions and events that can change issue keys. Two things I found that would change your issue key are:
  • If the issue was moved from one project to another. When this happens, the issue key updates to a new issue key number. Here is a similar instant in the Forums a few months ago.
  • If an admin changes a project key, Jira automatically updates all associated issue keys to reflect the new project key.
The history will show an entry just as you posted when the user updates the project key or moved the issue to another project with a different key prefix. But, users cannot change the issue key names, you're spot on.
Ratom
Thanks Liz,
You saved my day ! I was trying to replicate this event and couldn't. After reading pos asked user and confirmed that he did #1 from your list.
Best
Ratom
Like Liz Tanner likes this
FREE
