Dear all,
We have actually a Jira Data Center version 9.11.3 hosted in Azure AD.
We have our company Active Directory in Azure AD as well
We are working with external vendor and subcontractor for which which give them access to our central Jira .
We are handling user account in the following way:
Based on this context our company DO NOT and DO NOT WANT to manage subcontracors accounts in our AD
We are now studding the possible migration to Jira cloud from our Data Center instance by keeping the user management context describe above.
We have see that the first thing to do is do use Access in order to Verify our domain name.
Q1 : So I guess that we will have to verify each of our subcontract domain as well, right ?
Then we have notice also that when we verify a domain we need to claim return account . I understood that the list of users return after domain verification are user which have an Atlassian account. But by claiming user accounts, users will be manage in our company jira instance. THIS IS WHAT WE DO NOT WANT
Q2 : If we do not claim any accounts, and if we go to same account creation request process describe in step 1 to 4, does users will still be able to use the instance if not claimed or does new user will be automatically created as an Atlassian account ?
I hope you understand our goal and the key point which is that we do not want to manage external subcontractors users account in our futur jira cloud instance
Is this possible ? and if yes what are the exact steps to reach our goal
If it is not possible, what could be a workaround ?
Thnaks for sharing
Atlassian Access only allows one Organization to have claim to a domain - so it's unlikely you'll be able to claim each vendor's domain, nor want to.
You have two options here...
You could setup external user security for the vendor's users? This sends them a verification code when they login - and you can set the regularity these codes are required.
Ste
@Ste Wright thnaks for your reply
Based on your comment and if you are 100% sure that we cannot claim multiple domain.
Your option 1 is absolutely not possible in our company as we work with more than 500 external subcontractor account around the world and our security policy is strict on this
Your option 2 :
Please note that our subcontractors account do not have any Atlassian account as they do not use it for their own purpose and so do not have as well any own Atlassian Access
The way Access has been think of by Atlassian is weird and consider you simply work only for one instance of yours. But in todays world we work with many people around the world for which we simply want them access to our centralize tool
What else ? does anything else can be done ?
regards
You can claim multiple domains - but as I say, only one Org can claim each domain. That isn't to say you can't have multiple instances under that Org (eg. multiple separate Jira instances).
If the vendors do not have their own Atlassian Access Org, you could...
This might be an option you could consider?
It will claim every user though under each email domain, regardless if they are working on your instance or otherwise.
Ste
@Ste Wright , thnaks for your reply.
Our single company will handle a single our ORg with only one a single Jira instance which is our own
You said :
"It will claim every user though under each email domain, regardless if they are working on your instance or otherwise."
This is exactly what we are not allowed to do because we do not want to manage their account in our ORG
What is not clear in what I try to explain ?
@Ste Wright thanks for your reply.
So the way I understand when you use external user security is that :
Thanks for your reply on those still open question
regards
Ste
hello @Ste Wright , thanks for your reply
its getting more clear, still have few last question to cover all my case.
So to summarize :
Q1 - All accounts which has been claimed and which belongs to my own company verified domain, remains all Microsoft account from our Azure AD . They are not converted as Atlassian account as used as there are. Still correct ?
Q2- Lets consider this case where bob@global.inc is working for us and is handle as an external account in our ORG. If Bob is also working for an other customer which use also Jira cloud, does bob will be able to work with both customers ?
Q3 - Lets' consider this other case where I verify more than one domain .
- I verify and claim account on our own domain
- I verify then domains in our ORG of 2 external subcontractors Vendor1.com and Vendor2.com and then claim accounts for those domains. Both Vendor1 and Vendor2 have there own Azure Active Directory for managing their respective accounts.
So I guess in this scenario I guess I would have 3 directory sync entries :
One for our domain and 1 for each of those Vendor1 and 2. And each accounts are manage by each respective Vendor AD.
Is this Correct ?
Q4 : In the scenario describe in Q3, if Vendor1 and Vendor2 are working also for other customers and we as we have claimed their domain and accounts in our ORG, does Vendor1 and Vendor1 will be able to work as part of an other customer Jira cloud ?
What is confusing me here is that we have so called Atlassian account and Microosft Account from Identity provider and what I do not want is that when domains gets validated, Microsoft Accounts became Atlassian account.
Can you confirm that it is not the case and MS acounts remains MS accounts ?
Thanks for your comments
Ste
Thanks for your reply.
Let me explain this last case that his implanted today with our subcontractors.
Note : The way external GUEST are added to our AD is because we have setup and Fedration of Trust for their domain and are able to join after an invite is sent
Question :
What are the best practice to implement our current config to Jira cloud by keeping our GUEST access policy in place ?
Any suggestion ?
I'd recommend contacting Atlassian directly just to ensure either if this is possible, or what the best alternative is.
You can contact...
Ste
ok I will thanks for all your reply which help me to understand a bit better this wierd integration
rgards
hello @Ste Wright ,
I face to an issue that I sure you can help.
We have made a test in verifying our domain and Acess report 25 accounts thta we claim on that domaine in order for them to be able to sign-in using SSO
Question:
If a userB from that domain and part of the AD, which has not been claimed early as he did not get any atlassian account.
How that UserB request access and get claimed ?
regards
Hi @serge calderara ,
not a direct answer to your questions, but some insights on how Atlassian Access works, as I think you're mixing it up with some general admin hub functionality.
Atlassian Access enables single sign-on, user sync, and provisioning. It gives your org admins visibility and security across all the accounts, products, and sites within your Atlassian Cloud organization.
Before you can subscribe to Atlassian Access, you need to verify a domain and claim its accounts.
If you are able to verify domains of your subcontractors as your own depends on them. A DNS entry is needed to verify.
You can connect one identity provider when you subscribe to Atlassian Access, and connect to multiple ones when you subscribe to an Enterprise plan. User provisioning integrates an external user directory with your Atlassian organization. This integration allows you to automatically update the users and groups in your Atlassian organization when you make updates in your identity provider.
SAML single sign-on (SSO) allows your users to authenticate to Atlassian cloud products through your company's existing identity provider so they can access multiple tools with the same set of credentials.
An authentication policy allows you to specify authentication settings for different sets of users and configurations in your organization. This includes two-step verification and password requirements, for example.
On top, Access gives you the following features:
shadow IT: you can see sites and products that users with managed accounts created outside your Atlassian organization.
API Tokens: Users can create API tokens to perform authenticated operations with product APIs. With an Atlassian Access subscription, an org admin can revoke these tokens.
Atlassian Access audit log: tracks key activities that occur within the Cloud organization: changes to User accounts and Groups, Products, Security policies, and the organization as a whole.
Hope this helps a little.
@David Friedrich thanks for your reply but it is not make my mind clear based on the scenario I have describe
To explain again, our Jira is connected to our Single and unique Identity provider which is our Azure Active directory.
All our external subcontrators accounts are part of our AD but as GUEST accounts, which means their own account are manage by their respective company active Directory.
We do not want to manage external subcontractor accounts in our potential Jira cloud.
So the main point is as below :
Q1 : DO I have to verify Each domain of external subcontractor even if we do not want to claim their account ?
Q2 : Let say we validate each external agency subcontractor domain in addition to ours, but we do not claim any account from external users. What will happen when our unique Identidy Provider Azure AD will send users account to Jira cloud, does those external users will be still valid and enbale even if they did not get claimed ?
IMPORTANT :
We MUST use only our unique Azure ID where external GUEST account will belong to on demand
Thanks for your comment on
regards
@serge calderara Hi Serge,
Were you able to find answers to those question ? specially the last Q2 ?
We are in same situation as you, and we are not able to make Guest accounts working using SSO, even if we claim the accounts on Jira.
Were you able to connect your guest users using SSO using verified domains ?
Thanks for your answer
Help us plant more trees
