Users with permission to a Jira project report that they cannot log hours either directly to a ticket or their Timesheets for Jira. They see this error:
If you are open to try out alternate apps for logging hours and detailed time tracking reports, I can suggest the one we have developed
Worklogs Time Tracking in Jira & Timesheets
With this add-on, you can easily add the worklog authors and time tracking reports as a dashboard gadget. Main features of the app -
Disclaimer : I am part of the dev team
Hi @Lauren Pennisi 👋
Since the error appears inside Timesheets for Jira, the quickest path is to contact that vendor’s support team — they’ll be able to check the cause of the logging issue.
If you need a working alternative in the meantime, you might want to try JetTime. It offers:
Simple time logging with start/stop timers.
Worklog reports filterable by project, user, or date range.
Custom metrics and cost centers for billing or internal reporting.
CSV/Excel export for finance or payroll.
Privacy-first design — JetTime is built fully on Atlassian Forge and Runs on Atlassian, so data never leaves Jira Cloud.
👉 JetTime on the Atlassian Marketplace
— Anton, JetTime founder
Hi @Lauren Pennisi Lauren,
This issue usually happens due to Jira’s worklog permissions (missing Work on Issues) or time tracking configuration.
A practical fix is to use the Time & Cost Tracker for Jira (Timesheet | Budget | Reports) app, which simplifies time logging and avoids these errors. It provides:
Easy logging from issues or a clear timesheet view.
Validation to prevent invalid worklogs.
Detailed reports with filters by user, project, or date.
Export to Excel, CSV, or PDF for invoicing.
Forecasting and cost tracking on top of worklogs.
It’s an all-in-one solution for logging, reporting, and managing worklogs.
🔗 Request a demo call
📌 Free for teams up to 10 users on the Atlassian Marketplace
