Users cannot log hours to a Jira ticket because unknown error message. Why? What is the solution?
Lauren Pennisi
Users with permission to a Jira project report that they cannot log hours either directly to a ticket or their Timesheets for Jira. They see this error:
Anton from JetHeads_io
Hi @Lauren Pennisi 👋
Since the error appears inside Timesheets for Jira, the quickest path is to contact that vendor’s support team — they’ll be able to check the cause of the logging issue.
If you need a working alternative in the meantime, you might want to try JetTime. It offers:
  • Simple time logging with start/stop timers.
  • Worklog reports filterable by project, user, or date range.
  • Custom metrics and cost centers for billing or internal reporting.
  • CSV/Excel export for finance or payroll.
  • Privacy-first design — JetTime is built fully on Atlassian Forge and Runs on Atlassian, so data never leaves Jira Cloud.
👉 JetTime on the Atlassian Marketplace
— Anton, JetTime founder
Anastasiia Maliei SaaSJet
Hi @Lauren Pennisi Lauren,
This issue usually happens due to Jira’s worklog permissions (missing Work on Issues) or time tracking configuration.
A practical fix is to use the Time & Cost Tracker for Jira (Timesheet | Budget | Reports) app, which simplifies time logging and avoids these errors. It provides:
  • Easy logging from issues or a clear timesheet view.
  • Validation to prevent invalid worklogs.
  • Detailed reports with filters by user, project, or date.
  • Export to Excel, CSV, or PDF for invoicing.
  • Forecasting and cost tracking on top of worklogs.
It’s an all-in-one solution for logging, reporting, and managing worklogs.
🔗 Request a demo call
📌 Free for teams up to 10 users on the Atlassian Marketplace
Rahul_RVS
Hi @Lauren Pennisi
If you are open to try out alternate apps for logging hours and detailed time tracking reports, I can suggest the one we have developed
Worklogs Time Tracking in Jira & Timesheets
With this add-on, you can easily add the worklog authors and time tracking reports as a dashboard gadget. Main features of the app -
  • Create time reports in real time by grouping & categorizing data with aggregation
  • Prepare your reports based on Project/Sprint/Issue Type/Assignees and various other filters
  • Group your data to build more meaningful reports
  • CSV Export
  • Dashboard gadget
  • Enter Time Spent for multiple issues from Time sheet screen. With Calendar view and Board view
Disclaimer : I am part of the dev team
