Hi everyone,
I'm trying to write a script on Behaviours display or hide a field based on option selected from another field.
On a workflow transition screen, I have 3 fields:
If the user selects "YES" in Routine (customfield_18602) , then Fin Approve (customfield_18603) appear and CEO Approve (customfield_18604) should be hidden.
If the user selects any other value, then CEO Approve (customfield_18604) appear and Fin Approve (customfield_18603) should be hidden.
Please help me with this problem!
Thanks for your view and hope to your comment.
Hi @Thảo Nguyễn ,
please try the floowing code in your behaviour associate to Routine field :
def routineField = getFieldByName("Routine");
def finApproveField = getFieldByName("Fin Approve");
def ceoApproveField = getFieldByName("CEO Approve");
String routine = routineField.getValue()
if("YES".equalsIgnoreCase(routine)){
finApproveField.setHidden(false);
ceoApproveField.setHidden(true);
} else {
finApproveField.setHidden(true);
ceoApproveField.setHidden(false);
Hi @Fabio Racobaldo _Catworkx_
Thanks for your scripts. But I mean that when the user selects "YES" in Routine then CEO Approve(customfield_18604) should be hidden immediately on the screen.
I try on Routine field with Select List type and Radio button type but it doesn't work.
Please help me if there is any solutions about it.
Thank you so much,
Is ROutine a select list field or a radio button?
I try 1 Routine field is Select list and 1 Routine field is radio buttton.
But they don't work.
My code is for a select list filed. Please add this code to field "Routine" so it works each time that user cahnge its value.
Thank you so much,
It's my mistake when add script in Initialiser. I added it on field "Routine" and it works well.
Read the story
