Using Checklists
Cathy Covitz
July 17, 2024 edited
I have set up a checklist to automatically be added when a issue type = bug is created.
We are interested in running a report to see how many checklist items are in progress, skipped, etc,
Is there options to report on checklist items progress?  Thanks.
2 accepted
Cathy Covitz
Thanks!  I will try the JQL search.
Adaeze_Jude_HEROCODERS
July 18, 2024
I don't know if you're using an app, as you didn't mention it, but Issue Checklist Free or PRO will provide this report.
With Issue Checklist, you can perform a JQL search to get issues with a Checklist item or items in a particular status.
You can search using the query below:
"Checklist Text[Paragraph]" ~ "\\[skipped\\]"
Also, if you want to check the general progress of the Checklist, you can use the Checklist Progress % field to check the % progress of the Checklist.
"Checklist Progress %" > 80
 Please see our documentation for more context.
I will be happy to show you around the App. Please reach out to us here.
Oleksandr Haiun _TitanApps_ July 19, 2024
Hi @Cathy Covitz
In case you are using Smart Checklist or may consider it for your instance, this is how you can check the stats:
  • We recommend using the JQL search to find Issues containing searchable checklist items. For instance:
    issue.property[SmartChecklist].itemsStatus ~ ‘Todo’ OR issue.property[SmartChecklist].itemsStatus ~ ‘In progress’
  • You can see more examples in our documentation.
  • Take a look at the Progress on Agile board option and the visual representation of the progress per each checklist in the UI:Screenshot 2024-07-19 at 10.06.19.png
If you want to learn more, be sure to contact us directly here.
Best,
Oleksandr
