We Link Jira-Epics to goals. Wehen displaying these goals in Atlas, the Jira-Epics are not being displayed inline, if I use the Chrome Browser (Version 123.0.6312.123). Instead only textual Links are displayed, not showing the Epics name or Status.
If I use Firefox or Edge instead it works fine:
Deleting Browser Cache does not fix the problem.
I checked this, and the Epics show fine for me (albeit on an earlier sub-version of Chrome).
Could you try using Incognito mode, to see if that changes anything?
Ste
Hi @Ste Wright
thanks for this suggestion:
Do you have any ideas?
Sounds like it's a browser issue rather than a platform issue.
It could be related to one of your Chrome apps - try disabling them and see if this impacts what you see.
Ste
Found it!
The Chrome extension "nervenschoner" causes the problem. It seems that is not available anymore.
Many thanks!
Yeah, that's strange... Did it use to work for you in Chrome, @Markus Ebbecke ? Do you know if other users in your team are experiencing the same issue?
