I am looking at writing a sil script to check if a select list(called blocked) is set to YES for a Story. If it is set to YES, I want to then automatically set the parent EPIC blocked select list to YES as well.
Is this possible with sil scripts?
I assume that in the meantime you have already managed to write this script, right?
Let me know if you still need help with this.
