Using Quick Filters in Active Sprint board
Devi Vaishnavie December 29, 2022
When I am trying to view only Bugs and Stories, it shows no issues available. Though I've multiple stories and bugs available in Active sprint.
I think JIRA is trying to do "Stories AND Bugs" instead of "Stories OR Bugs". Can someone advice me more on this?
Trudy Claspill
Hello @Devi Vaishnavie
If you activate multiple Quick filters that uses the AND operator to combine the filters. Only issues that match all the criteria in both filters will be displayed.
If you have one Quick filter for displaying bugs
type = Bug
...and one Quick filter for displaying stories
type = Story
...and you activate both at once then the effect is this
type = Bug AND type = Story
Since an issue can have only one type, no issues can satisfy that filter condition.
If you want to display both Bugs and Stories on your board using a Quick Filter, you need a separate Quick Filter that uses this
type in (Bug, Story)
Devi Vaishnavie January 4, 2023
When no issue type could be of both "BUG" and "STORY", why do we need to have the filter should work as BUG AND STORY, is my question!!
Nic Brough -Adaptavist-
January 4, 2023 edited
Because the point of a quick filter is to hide stuff you don't want to see, so that you can drill down into a board.  It would make no sense to have "or" with quick filters, it would stop you being able to drill down.
Jack Brickey
December 29, 2022 edited
Hi @Devi Vaishnavie , assuming you are using CMP project here. Can you have a look at the JQL under Board settings/quick filters?
Yes, its CMP
