Using a Custom Picker field with Proforma Form
Jamie Rogers
April 17, 2023
I think I am hitting a limitation with Proforma forms and using a custom picker field (scripted field).
  • Can anyone on the community answer if this is possible?
Our use case is we have a scripted field returning a custom list of choices and this works well on regular Jira screens. However when using a Proforma form the option to map to this field is not there so it would appear I cannot do this.
Ken McClean
May 4, 2023
Hi Jamie:
If you've add the scripted field to the project under which the form is being created, and the field still not showing as available to the form, I would say you're correct.  There are quite a few limitations on the types of fields that you can add to a ProForma form, unfortunately.
Ken
