Using automation to add an existing epic to a new issue
Tracy Boyd April 17, 2024
We have an automation that is run monthly because of a schedule-based trigger.
This automation creates tasks that go directly to the backlog and are not added to a specific sprint. However, we would like to use the Parent feature to link them to an Epic.
That being said, the options for linking to a Parent only show "trigger" or "current". How could we use the Additional Fields and JSON to link to a preexisting Epic.
We tried this:
{ "fields": { "Parent Link": {"key" : "SMC-107"} } }
Kalyan Sattaluri
April 17, 2024
Hello @Tracy Boyd
You dont need to do advanced edit.
Just choose the field in the drop down and give the key, like below screenshot.
But if you do want to use Advanced Edit, you can use below JSON:
"fields": {
"Parent Link": "SMC-107"
April 17, 2024
Hi @Tracy Boyd
As the sunset of the "parent link" field proceeds, I recommend using the "parent" field.  Please look here for some information, but not the specific timelines as that has not be announced fully.
https://support.atlassian.com/jira-software-cloud/docs/upcoming-changes-epic-link-replaced-with-parent/
FREE
Let's build A Rovo Agent 🤖
Save your spot
