Using checkbox custom field in condition to transition
ADM Amar Msaid
i have a checkbox custom field and i want to use it  in condition to to make visible or not to the user a transition from one status to one other status.
is it possible and how can i do it from the UI or another way?
How can i implemente theses rules:
1- make visible the transition if one of the options is checked
2- make visible the transition if any of the options is checked
3- make visible the transition if a specific option (say the option Validation juridique) is checked.
Thank you.
John Funk
Hi @ADM Amar Msaid
You should be able to do that by adding a Condition for Value Field. Then choose the field from the list and add your Condition and Value.
Register here ⬇️
